Can I use a different DSL modem in each of two different rooms, instead of using a router? Using Verizon DSL.
Two modems in one residence?
Dec 16, 2004
Most relevant reply
No. One modem per DSL subscription. Further questions, go to the following Verizon News Group news:// Dave | Can I use a different DSL modem in each of two different rooms, instead of | using a router? Using Verizon DSL.
Read the full replyNo.
news://news.verizon.net/0.verizon.adsl
Dave
Thanks for the quick reply. I'll subscribe to the more appropriate newsgroup.
Likely not. I know with SBC if 2 DSL modems are plugged into the same phone line, neither will even sync, much less connect (even if 1 is powered down). Even if not a physical limitation, you likely only allowed
1 DSL login per account.A wireless router is a better option if you do not want to string network cable.
Sure you can. You just have to get two separate phone lines with two separate DSL accounts. If you want to have one phone line and use two DSL modems on it then the answer is no.
What is it you want to do?
I have an extra Westel Verizon modem, and figured I might be able to use it in a different room without having to send a wire from the other to it. Right now I don't want wireless. Anyway, I have hooked it up with a cable going from one room to the other.
Ralph Alvy wrote: : Can I use a different DSL modem in each of two different rooms, instead of : using a router? Using Verizon DSL.
Why would you want to do that? You'd need 2 separate DSL connections. And the workstations would not be on the same physical network.
