Speed Touch 330 now fails to work??
Sep 13, 2005 1 Replies
Tyson
My brother has the same speedtouch modem and the connection wont work properly for him too, the two lights light up on the modem but it often disconnects for some reason, and he got the bt people to come round and try to fix it but they say there is nuthing wrong with it, but…
My friend has an adsl connection to Wanadoo via speedtouch 330 modem. It was working fine, but now has stopped and on running the Dr speedtouch diagnostics, I note that the test fails at the first stage, giving a message saying that the PC's (XP Home) tcpip is not installed. Problem is that TCPIP is installed on the device. If it's any help, she has kids who click any rubbish that comes up on the music and nonesense sites they visit, so I reckon they've probably done something, though they don't fiddle with the techie bits - they just use the thing. I note that the ADAWARE anti spyware programme that I installed last time there were problems has now vanished and the whole system seems slow to me.
I tried to unistall TCPIP so I could re-instal it, but this doesn't seem straightforward on XP which I'm not familiar with - I use 98SE and Windows 2000, where you can simply delete a protocol, but in this system it seems more tricky.
The modem does seem to connect to Wanadoo, but nothing happens when I run explorer, just after a while, I get a message saying that the page cannot be displayed. All was fine just a while ago, and both lights show on the modem so the USB and line are OK.
Do any of you have the time to suggest something - sorry to ask - I know this will be a pain.
Regards
EvilV
modem.
tricky.
