Can't seem to get 802.1x to work
May 15, 2006 2 Replies
Can't seem to get 802.1x to work open original image
Hey all, I'm trying to setup 802.1x using PEAP authentication. I have the following setup in my lab:
2003 Server running SecureACS 4.0 with CA installed a 3550 Cat switch running 12.2 SEE IOS a Windows XP SP2 laptop with 802.1x authentication enabled
The problem is I can not choose PEAP settings on SecureACS because it keeps giving me an error that a certificate has not been installed even though I have installed it. I followed this guide here:
and here
pretty much to the E, and still no luck. I install the certificate, and it tells me its been installed and to restart the ACS service, and I get the same error message saying it's not been installed.
Has anyone seen this before?
Okay, I managed to get PEAP working now after some painful troubleshooting but now am getting this message when a machine tries to authenticate:
EAP-TLS or PEAP authentication failed during SSL handshake
invalid. What does that mean? Do I have to manually install the certificate generated for my ACS server into each client machine with
802.1x enabled?
psychogenic wrote:
I have seen this before when I had setting incorrect on my clients. for example when I had WPA with AES or WPA2 with TKIP I got this error.
