status stuck on "acquiring access"
Oct 13, 2006 2 Replies
My laptop is stuck on acquiring access status. What are the common issues related to this prompt? My roommate's laptop connects ok just 5 feet away on the other side of our room.
On Thu, 12 Oct 2006 21:50:25 -0500, Capt Jack wrote in :
Hard to say without a lot more detail.
No way to tell without some clue as to what hardware and software you're using. However, my guess(tm) is that it's failing because it has the wrong encryption key. If you're using WEP, please use the longer Hex key instead of the ASCII key as there are key conversion issues.
