Acquiring network address forever!
Feb 06, 2008 1 Replies
Ok...
I am running windows XP SP2 on both my desktop and laptop. I have a Zoom ADSL 6x Router and a Belkin High Speed Mode Wireless G USB Dongle.
I have been able to go online with my laptop many times before, but today when I try to connect it gets stuck on acquiring network address. My signal strength is to the max. I have it auto connect when in range, so I do not have to enter a key. My PS3 connects to it fine. I am using Windows Network Connections. I have all the TCP/IP on automatic. Rebooted and nothing works. Unplugged and plugged my USB dongle. Nothing works?
I can't think of any more information but I will give it if asked.
Thank you, Luke
On Wed, 6 Feb 2008 15:25:40 -0500, lukejames1111 wrote in :
Some setting must have changed. Suggest:
  • Checking the wireless router status screens to see if any security is on (e.g., WEP, MAC filtering).
  • Uninstalling and reinstalling the USB Wi-Fi adapter.
  • Resetting the wireless router to hardware defaults and starting over. Disable all security settings when troubleshooting.
