Needing help!
Jul 30, 2007 1 Replies
Hi everyone!
I'm a newbie at this forum and came here for help. I have a wireless problem for my PC. I'm using Netgear and using a mini-antennae for my PC (Windows 2000). When I connect through Netgear, the signal only goes to around 60% max., which doesn't allow me to connect to the Internet. I didn't have this problem with a weak signal before and wondering what's going on.
I want to know how I can strengthen my signal. Hopefully, someone can help.
Sarah
  • Which Netgear? Which Mini Antenna? What were you doing before when you could connect? (In other words what did you change?) How far are you away from Wireless Access Point with your PC and mini-antennae?
What's the Internet Connection? Does it work through a wired connection? What do you IP Address and Gateway and DNS on the puter look like?
