linksys wga54g
Aug 23, 2005 5 Replies
Most relevant reply
<j_willis
Only a thought but try disabling your firewall if you have one, mine stopped me accessing the set-up screens. Cheers T
Has anyone got one? I have a problem with mine:
  1. the set-up software will not recognise it.
  1. I can ping 192.168.1.250 (management ip) but as soon as I attempt to access via a web browser I have a problem. I am able to input the default id and password but the browser hangs. If i try a ping
192.168.1.250 -t at the same time all is well until I input the password and hit 'enter'; then the ping times out.
  1. the power light is, after the unit has been on for 5 seconds or so, always orange. surely, if it is working correctly it should be green?
Please don't give me any advice about wireless set-up or encryption - I have not got that far yet as I have not been able to manually configure the device!
TIA, Damo
Not sure about the wga54g but the wrtgs54 & befsx41 but run with a green led ... didnt look for the manual for what orange means, are the setting factory default? if not might be worth a try.
Is it new/ new to you? have you logged in before etc?.
Andrew
That's the problem. It is an ebay purchase.... I have only managed to get as far as I have said in my OP.
ok, the manual (ftp://ftp.linksys.com/pdf/wga54g_ug.pdf) mentions the light should be green, and does not mention an orange or amber led.
It looks like simply pressing the reset button does the factory reset, i.e. it does not say for how long ... as the .250 is the default address it may not make a difference, but worth a try.
Not sure if you can reload the firmware via tftp, it only mentions the web interface, that might be the problem as is has basic connectivity vi ip and things seem to go bad (oragne) after some inital tests are run
good luck.
A.
had it confirmed by linksys support that it is a firmware problem. no way of fixing via tftp (which I guessed). pity.
