cisco 828
Mar 21, 2006 14 Replies
Jump to replies (14)
hi all, just got a cisco 828 router and a sdsl line.
problem is that the web setup hangs on the 'loading cisco router web setup. please wait...' screen.
i have set the router to use annex b - which has enabled the carrier detect light to green.
i ve manually entered my ip address, but havent a clue how to continue to setup the unit from a terminal.
can someone help me out here as i'm under pressure to go live as soon as possible!!
thanks in advance!
andy shiny pc ltd
comand line configuration guide can be found on Cisco web site at
andy everett schrieb:
Use Netscape Navigator 4.79 or 4.8 without external Java plugin and CRWS will work.
im using server 2003 x64 enterprise edition - i cannot get netscape 4.x to install.
is there any other browser out there that will work with th router?
or any other way i can configure it easily, only need to set that atm0 ip address username for logging into the shdsl service provider and password for the same
thanks
i've just tried that too v1.5.01
im getting way further with the setup than before with ie
now (with firefox or netscape 8) i get to the same loading screen, but with a menu tree for the setup below it, and a popup window supposedly checking the settings from ios? but it stays there looping a progress bar indefinately.
java console info:
Java(TM) Plug-in: Version 1.4.1_02 Using JRE version 1.4.1_02 Java HotSpot(TM) Client VM User home directory = C:\\Documents and Settings\\AdministratorProxy Configuration: Browser Proxy Configuration---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message l: dump classloader list m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system properties t: dump thread list v: dump thread stack x: clear classloader cache
0-5: set trace level to
---------------------------------------------------- java.util.regex.PatternSyntaxException: Unknown character category {XDigit} near index
9\\p{XDigit}{1,4}\\.\\p{XDigit}{1,4}\\.\\p{XDigit}{1,4}\\.\\p{XDigit}{1,4} ^ at java.util.regex.Pattern.error(Unknown Source) at java.util.regex.Pattern.familyError(Unknown Source) at java.util.regex.Pattern.retrieveCategoryNode(Unknown Source) at java.util.regex.Pattern.family(Unknown Source) at java.util.regex.Pattern.sequence(Unknown Source) at java.util.regex.Pattern.expr(Unknown Source) at java.util.regex.Pattern.compile(Unknown Source) at java.util.regex.Pattern.(Unknown Source) at java.util.regex.Pattern.compile(Unknown Source) at java.util.regex.Pattern.matches(Unknown Source) at sun.plugin.cache.FileVersion.convertToLong(Unknown Source) at sun.plugin.cache.FileVersion.(Unknown Source) at sun.plugin.cache.JarCache.verifyFile(Unknown Source) at sun.plugin.cache.JarCache.match(Unknown Source) at sun.plugin.cache.JarCache.getMatchingFile(Unknown Source) at sun.plugin.cache.CachedJarLoader$4.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.plugin.cache.Cache.privileged(Unknown Source) at sun.plugin.cache.CachedJarLoader.getCacheFile(Unknown Source) at sun.plugin.cache.CachedJarLoader.(Unknown Source) at sun.plugin.cache.JarCache.get(Unknown Source) at sun.plugin.net.protocol.jar.CachedJarURLConnection.connect(Unknown Source) at sun.plugin.net.protocol.jar.CachedJarURLConnection.getJarFile(Unknown Source) at sun.misc.URLClassPath$JarLoader.getJarFile(Unknown Source) at sun.misc.URLClassPath$JarLoader.(Unknown Source) at sun.misc.URLClassPath$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at sun.misc.URLClassPath.getLoader(Unknown Source) at sun.misc.URLClassPath.getLoader(Unknown Source) at sun.misc.URLClassPath.getResource(Unknown Source) at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at sun.applet.AppletClassLoader.findClass(Unknown Source) at sun.plugin.security.PluginClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.applet.AppletClassLoader.loadCode(Unknown Source) at sun.applet.AppletPanel.createApplet(Unknown Source) at sun.plugin.AppletViewer.createApplet(Unknown Source) at sun.applet.AppletPanel.runLoader(Unknown Source) at sun.applet.AppletPanel.run(Unknown Source) at java.lang.Thread.run(Unknown Source)
thats what i get if it helps? "andy everett" wrote in message news:2NVTf.253750$ snipped-for-privacy@fe2.news.blueyonder.co.uk...
Try downloading Cisco SDM software to you PC and see if it works with the 828.
It is the replacement for CRWS
get SDM-V22a.zip
Install to your PC not to the router
do i need to be a registered cco user?
no
just click on
and follow download instructions
you can use anonymous user id
great idea, thing is that it doesnt work on the 828 router.
i installed the latest java pack and the full web setup window appears, but the checking module still sits there looping a progress bar in netscape 8.1
any more ideas really welcome!
compare this to what you have already
interface ATM0/0 no ip address no atm ilmi-keepalive pvc 0/35 encapsulation aal5snap
pvc 8/35 encapsulation aal5mux ppp dialer dialer pool-member 1
dsl equipment-type CPE dsl operating-mode GSHDSL symmetric annex B dsl linerate AUTO
interface Dialer1 ip address negotiated no ip directed-broadcast ip nat outside encapsulation ppp dialer pool 1 ppp chap hostname < >
ppp chap password < >
ppp pap sent-username < > password < >
dialer-list 1 protocol ip permit
interface Ethernet0 no shut ip address 10.10.10.1 255.0.0.0 ip nat inside no ip directed-broadcast
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 dialer1
access-list 1 permit 10.10.10.1 255.0.0.0
828 - G.SHDSL Troubleshooting
ok
the settings i was told to put into the router are : PPPoA, with VC as the encapsulation, VPI is 0 and VCI is 38, DNS servers are
195.74.102.146 and 195.74.102.147
btw i've got the web setup running in internet explorer now. still havent got it to work 100%.
my main issue was the fact that the annex setting is set to A when apparently for europe it needs to be on B is that right and if so whats the fastest way of doing that, as the web setup doesnt offer that change?
thanks so much for helping me out !!
fast way is via comand line interface CLI which you can access via console
Cut and paste the follwoing, once you are at the enable prompt on the console
conf t interface ATM0/0 dsl operating-mode GSHDSL symmetric annex B end
wri mem
the
