linking 2 LANS over the internet, possible?
Sep 09, 2007 3 Replies
Adair Winter
The easy way is with hamachi ( just install it on every machine that you want to share data with and build your own network, you will have access to every resource as if you were on the local LAN. There are other ways but they can be more complex. we need more info about what…
hi
i have a small basic LAN in my house, but i am wondering if i can link it to my cousins LAN in his house?
is this possible? if it is, is it worth it?
cheers
Yes it's called a VPN. The easy way is with hamachi
There are other ways but they can be more complex. we need more info about what you are doing and what type of hardware you have.
Adair
"Adair Winter" hath wroth:
Close. Try:
Ack. Yes, it's
didn't even notice that when i first typed it. reguardless, fantastic software.
Adair
