Limited, but no Connectivity
Dec 29, 2007 0 Replies
I think, this is a simple issue that can be fixed.. but i'm not the best with this kind of stuff.
I have 4 signal bars out of 4, but it is not finding my IP address automatically. I try to input it manually, but i'm not sure if i'm inputting the IP adress wrong... or maybe that is not the issue i'm not sure. I don't think it is the computer though, because my friend also had this issue when trying to connect with the router... yet my sister is able to connect from her computer fine. Also, i'd like to state I can connect with an ethernet cable, but that defeats the purpose of using the computer from my room, and not right next to the router.
The router is Wireless-G 2.4 GHz Linksys router.
