Freezing laptop with D-Link DWL-G122
Sep 13, 2005 2 Replies
Hello, All!
My problem is quite simple, hope the solution is too...
I installed a D-Link DWL-G122 Wireless USB dongle some weeks ago. Installed software from CD first, shut down the compu, connect the dongle and startup compu.
Appr. since then, my laptop (Acer 1353LC) is freezing sometimes, and quite frequently, once or twice a day. I have to power down and up to get it working again. Does anyone has had a similar problem with this D-Link dongle and knows THE solution?
Thnx... With best regards, EDJO.
EDJO
Does it freeze with any network connection, or just the DLink? What happens when you go wired?
Chris
Hello, NetSteady! You wrote on 13 Sep 2005 05:28:40 -0700:
N> Does it freeze with any network connection, or just the DLink? What N> happens when you go wired?
Before using the DWL-G122, I had no trouble with a Sweex 802.11b USB dongle. I asume a wired connection will give no trouble (Did not try it, though)...
The D-Link dongle works great, but the freezing of my LT is an annoyance.
