DI 624, restricted access ?!?
Mar 26, 2006 4 Replies
Duane Arnold
What IP from the router is the machine using when you enter IPconfig /all at the DOS when you select the Start/Run and enter Command or CMD and enter IPconfig /all? Duane :)
Hi
I have a problem accessing the Internet using WiFi connection
It firstly appears when a friend has tried to connect the Internet He was able to visit google but no other sites (in fact, we finaly arrived accessing about 3 sites :S) I was able to access all
Shortly after, I formated my hard drive and so, i can't access the internet anymore, just google (and subsites, like google groups :D)
By LAN, there is no problem, all is accessible
I tried to upgrade firmware to 2.70, reseting factory setings, by the router web admin, and by the little button hidden behind it
I tried to connect to another router (a linksys) no problem.
Thanks in advance (and sorry for very bad english)
Duane :)
I got This (With translation :D)
Wireless connection : DNS Sufix : Description . . . . . . . . . . . : NETGEAR 108 Mbps Wireless PCI Adapte r WG311T M.A.C. . . . . . . . . .: 00-0F-B5-88-35-90 DHCP enabled. . . . . . . . . . . : Yes Automatic configuration enabled . . . . : Yes IP. . . . . . . . . . . . : 192.168.0.100 Network submask . . . . . . : 255.255.255.0 Passerelle par d=E9faut (gateway?). . . . . . : 192.168.0.1 DHCP Server. . . . . . . . . . . : 192.168.0.1 DNS Server. . . . . . . . . . : 192.168.0.1 Bail obtenu . . . . . . . . . . . : lundi 27 mars 2006 15:22:22 Bail expirant . . . . . . . . . . : lundi 3 avril 2006 15:22:22
Oh, My router is configured at 192.168.0.1, I can access some types of adresses and nslookup always return an IP adress from any domain names
nslookup
Nom :
Address: 193.121.210.226
but I can't access neither
nor http://193.121.210.226 I can access JVC canada without any problem
I have contacted D-Link, the problem is with my modem (freebox V4 pour ceux qui auraient le probl=E8me) and so linked with my ISP
Pour ceux qui auraient besoin : Passer la freebox en mode routeur (sur le site de free) et changer l'ip du routeur en 192.168.1.1
