DI-624 Lost Connections
Apr 27, 2006 5 Replies
Jump to replies (5)
Has anyone found a solution to the following? With firmware version
2.50 for DI-624, I was frequently getting "A Network Cable Is Unplugged". After I upgraded to 2.70, the error message is no longer appearing.
But I am still experiencing lost connections -
  1. I lose connections to our terminal server and have to restart applications.
  2. Downloads from internet stop midway.
These problems occur for the computer that is directly connected to the router if the Wireless Access Point is enabled. If this is disabled, I do not have this problem. I am using a single channel. I do not see anything helpful in the logs. Has anyone found a way to fix this? I have contacted DLink but have not found a solution yet.
Perhaps it is being swamped by filesharing connections.
check you mtu must be at 1492 for dsl normaly
Only with PPPoE.
It could be this. I only have one BitTorrent client installed and it is not running at the time. But other users could still be trying to connect to my machine. The only message I see in the logs were packets that were dropped by the router because one of the ports was closed. How can I monitor activity on ports and if it is this, how can I fix this besides avoiding connecting to these these applications? Can I change settings?
I suggest sharply cutting back on the number of connections in all filesharing clients.
