wireless-to-wireless connectivity?
Mar 25, 2006 4 Replies
Mike Schumann
Buy Access Points or Routers that can function as repeaters. One example is the CompUSA brand 801.11g Router. In the past it has been on sale for $9.99 after rebate. Mike Schumann
Hello,
This is a followup to a previous post about sharing wireless across buildings. I have Internet access at point A. I can get a good wireless signal at point B. From point B, I can send a good wireless signal to point C. But point A and point C cannot be connected wirelessly due to obstructions. Further, points A, B, and C are in different buildings, so certainly can't be connected together with wires.
My question is: How can the guy at point C connect to the Internet through point B? It must be possible, at least from a physics perspective. All the diagrams I've seen about wireless access points has the AP attached to the first router with a cable. Seems this ought not to be necessary. Am I missing something simple?
thx,
Thomas
Hi, Can you move access point to point B?
Mike Schumann
OK. My Netgear RangeMax 824 doesn't say it can be a repeater, but the
802 Access Point model does, so I ordered one of those. I bet it's just a software difference, and if I had the inclination I could find some firmware to make the 824 work, but this solution ought to work fine. Thanks for the help.
Thomas
Your best bet is to put both a Wi-Fi client (for communication with point A) and a Wi-Fi access point (to host communication with point C) at point B, cabled together with Ethernet, running on different non-overlapping channels. In addition to avoiding the speed loss and other hassles of a repeater, this would allow you to use directional antennas if needed at point B.
