Configuration issues (firewall) with DI-524 D-Link
Apr 27, 2006 21 Replies
"UH" hath wroth:
Model number of AirStation?
guessed at the model number. Start from the main page if I guessed wrong. Be sure to either use a static IP address for your workstation, *OR* use "static DHCP" or "preassigned DHCP" to create the same unchangeable IP using the router configuration.
Hi Jeff -- it's another model number, but the menu is the same. This is exactely how it works. Thank you so much! All the best from rainy Hamburg to (sunny?) Santa Cruz, Ulrich
