The easiest way to make free calls to other people using your ATA or other SIP-compliant VoIP gear is to sign up for a number at Free World Dialup
miguel
It has to be compatible with their software and protocols, but that usually gives you a lot of options. If the provider sends you an ATA, it will come pre-configured. Otherwise you have to configure it (using a web-based or phone-based interface) with settings they give you.…
miguel
Not a Problem thats what most people do.
Well the answer to this is a yes / no on one. Put simply yes you could make P2P calls without a Voip Provider, BUT why would you want to, Firstly it will make it dificult for people to call you, and you wont be able to get the benifits of reduced cost toll and International voip to pstn calls. Most SIP suppliers dont charge any "line Rental" just charge for off net calls, look for suppliers that have good peering to other voip providers.
Ian
FWD 43143
Or
Ivor
I'm new at this, so if anyone could provide a little information that would be great.
I'd like to use my cordless phone to place voip calls so I know I need a ATA analogue telephone adapter. I'd like to plug the ATA into my Dlink router via an ethernet RJ45 port so I don't need the computer running in order to place a call. It also means other family members are not tied down to my computer as with USB/Headset software solutions.
The thing is, can I then make a P2P call to another voip user if I don't have a provider? Must I absolutely have a provider if I don't want to use a software solution or a USB solution?
Thankyou.
Yes, you'll have to dial by IP address in that case. And if they are behind NAT (e.g., a home router) then it probably won't work unless they have made special arrangements on their router. In this case you are better off using FWD as I mentioned earlier in the thread. It's free and easy.
If the provider is far away from you then there can be noticeable latency.
For instance, I live in Malaysia but buy SIP minutes from a provider in the USA. For calls to the USA and Europe, and even Japan and Australia, this is no problem. However, when I call back to countries near me (such as Thailand, or Malaysia itself) the delay is quite perceptible because the information is traveling twice around the world over apparently high-latency links.
So even though calls from Malaysia to Malaysia using VoIP via the USA are cheaper than calls directly dialed from my Malaysian phone, I still end up direct-dialing because the delay is so annoying.
miguel
The ATA has the info programmed into it.
No The ATA is the device that will let you make the call
No realy The important thing is latancy, So if you intend to call people mainly in NZ use an NZ supplier , But for example if you are going to use it to contact people in the UK use a UK supplier get a UK number and that way they call you on a UK number IF they dont have voip and you can call them at local rate if they dont have voip or you do a P2P call
Have a google the are some very good voip companies in NZ
Ian.
Thanks for the replies. I guess I'm having trouble visualising how it all fits together. For instance,
do I need an ATA adapter which is specific or constructed by a particular provider? If not, how does the ATA which is plugged into my router know the ip of the provider or where to send the data?
If I don't have a provider, how can I then make a P2P call to another voip user? The ATA is just a digitizing device and knows nothing else..?
Does it matter where the provider is located? I'm in New Zealand...
Thanks again.
Thanks Miguel,
that was very useful!
Oh, and if I may, what ATA should I be looking at for the straighfoward RJ45 setup I have in mind? Where can I find such a thing as there don't appear to be any availabe in NZ.
these move fasts..
For crying out loudl will you *please* stop spamming this group..?
Ivor
