Basic Help
Oct 09, 2007 1 Replies
New to this job and phone system. I found a 466 page manual that is somewhat close to the system we have. They only want me to program calls to come in to one extension. The welcome message gives 3 options. For wholesale dial 0 (this to rings 13). For new orders press 1 (this rings extension 10). How do I make it go to extension
10 whether they press 0 or 1? I know how to get into the system to enter a code. I was able to correct the time and date. I just don't know what code to use to change what extension rings. Not familiar with the terminology used in the manual, such as pool line, group, line coverage etc. so I don't know what to choose. Our system is a Lucent AVAYA ACS 6.0 Partner BTOEM Version PACS R6.0.4 C01 Phones are Partner 18D and 34D. As far as I can tell the systems provides Extensions 10 thru 17 and maybe 3 incoming lines attached. I guess I need programming for dummies on this system, but would be happy if you could just provide me with one of the 3 digit codes that I should use for now.
Thanks, Dave Syring Chatsworth, CA
sounds like manuel you have is for the phone side and not v. mail side. you need to log into voice mail and make your changes. i beleive it is icm 777. then when asked enter mailbox number enter mailbox "0" passcode by default is 1234. listen to the prompts. you want to get to the area of selector codes and simply change selector code 0 to ext10 instead of 13. hope this helps.
rod
