strange hangup [Telecom]
Mar 04, 2008 2 Replies
I'm looking for an old classmate and found the number 2164210095 but it rings once then goes floop floop floop and hangs up. I've never heard of this before. Is it a feature, a bug;-) or a blue box or what?
(Yes, it's in the right area code and state.)
Sounds like you have dialed a telephone company test number, maybe battery/ground, either that or he has problems on his end with something.
That actually sounds like a problem I once had with my phone line years ago, although I didn't make a note of the exact noise I heard when I tested it from work.
On an incoming call, the ring voltage would apparently be enough to short the phone line outside, so I'd be lucky to hear a single ring inside. I don't know exactly what they did to finally fix it, but I suspect they simply replaced a section of the line.
