How to default a simon 3 panel
Oct 29, 2006 7 Replies
Crash Gordon
I usually take the elevator to the highest floor and toss it over the parapet into the nearest dumpster. | Hello all. Just found this site. I Just bought a house it has an adt simon | 3 panel installed. | I'd like to default the program. No one has the master or user code. |…
3 panel installed. I'd like to default the program. No one has the master or user code. TIA
Thanks for the honest reply. I've never had any dealings with the simon panels.
You are correct... :) I have never worked on a Simon panel. Sonitrol panels can be defaulted by shorting out a few pins on the panduit conections. Other brands I have worked on u can do it through the keypad. I looked through the manual but couldn't find any information on how to default the program. Thanks for the reply...
Hi, this works with a simon 2 and may work for a 3
Reset Memory to the Factory Defaults If it becomes necessary to set all programming back to the factory defaults, do the following:
  1. Open the Control Panel cover.
  2. Unplug the transformer and the battery.
  3. Simultaneously press Cancel, Clock Set, and Minutes.
  4. Restore power to the panel with either the battery or the transformer while pressing these three buttons.
  5. Plug in the transformer or connect the battery. NOTE: If Phone Lock is on, options 04, 05, 06, 08, 09,
12, and 13 will not reset to their defaults.
sonitrol via HomeKB.com:
The Simon 3 uses Minutes+
