First attempt at home automation
May 26, 2006 2 Replies
Hello I am trying to set up a home automation system and so far have installed an OMNI IIe controller and I believe I have that part of it working. I can access it from my PC so I believe I have it at least half working. What I can't seem to figure out how to do is I want my OMNI controller to turn on and off a UPB standard dimming switch from Simply Automated. Is this possible to do? And if it is working should it just show up without any problems or is there a trick to getting Simply Automated components to work with a HAI controller?
You might try the discussion groups at
-- you will likely find your answer there.
Kurt
