Sygate Pro and freeware-Can freeware be made stronger?
Jul 27, 2004 2 Replies
Kerodo
You could try copying all the .dat files with current dates from one machine to the other, however, you might run into some compatibility issues, not sure. The Pro version allows more features and more rules and there might be other differences as well. Try it and see what…
I have 2 PC's. One with a paid Sygate Pro license and one with the freeware version. Since I am between jobs (no excuse I know), is it possible to use the definition file or something from the Pro version update with the free version on my other machine?
Thanks so much, Patty
You could try copying all the .dat files with current dates from one machine to the other, however, you might run into some compatibility issues, not sure. The Pro version allows more features and more rules and there might be other differences as well. Try it and see what happens. Worse case is you'd just have to reinstall Sygate on your 2nd machine again..
Thanks. Will try it. Else I will just buy another license.
I assume there will be file differences of course.
Appreciate it. Patty
