Sonicwall Wall TZ 170 VPN Connection
Jan 07, 2006 3 Replies
Jump to replies (3)
I have a TZ 170 at work and i have the global VPN turned on, and i have the settings exported out and then imported them onto my laptop. I setup the Virtual adaptor and assigned it a free ip address that is free from my network, then i start the connection on the group VPN and put in my password and login, then the connection shows a connection. This is all good, but then i try to find one of my network devices or use a terminal connection through reflections software and connot get any connection. Any idea as to why i cannot see any thing inside the network or get a connection? Thanks
so you have remote VPN client -->VPN host and want access to Mapped Drives?
Yes i would like to be able to access the resources on teh network and use a WRQ reflections to access a server on the network.
That is part of what i would like to do , the other is use the WRQ reflections program to access a server inside of the network so i can work when i am not in the office. All of the machines inside of the netowrk are all on the same subnet and my home machines are also on the same subnet.
