Sonicwall Global VPN help
Jul 13, 2007 0 Replies
Our VPN tunnel connects a SBS2003 server using a Sonicwall TZ170 standard OS firewall to a XP Pro Sp2 laptop. The SBS 2003 end has a static IP address, but the laptop is dynamic. Whenever I want to make a VPN connection I have to open the VPN client and then open the virtual adapter under "network connections" and "repair" the connection. Then I can enable the vpn connection in the client. If I do it in any other order or omit any steps, the client will not connect.
Is this standard operating procedure or do I need to do something to circumvent this? Its not a big deal (I do have a connection afterall), but I would like to save myself the extra steps.
Thanks in advance.
