Sonicwall TZ 170 - VPN problem
Jan 28, 2006 0 Replies
I'm unable to successfully terminate VPN connections with the "Global VPN Client". I've configured a local user on unit and as far as I can tell setup a working VPN configuration. I can connect to the TZ 170 and there are no errors in the log, but I can't send traffic to anything on the inside. No DHCP adress is issued ethier, but i've tried using a static IP/mask on the Sonicwall adapter.
Any help would be apreciated.
CH
