Problems using Google Earth and Maps... (When connected through router)
Jan 07, 2009 1 Replies
I am having issues when I am at home on my wireless router that i don't have when I am at work. (I have a MacBook Pro laptop that goes back and forth between work and home as well as an iPhone)
I noticed that when I am at home, and run google earth on the laptop, that I get an error message saying it can't connect to some server. I run the application at work and it works fine.
I use the maps application on the iPhone at home and get a similar error when I use the WiFi connection. However if I disable the wireless (and use the 3G) the maps application runs flawlessly.
Any Ideas what might be causing this? I suspect its a port that needs opening, but I have no clue which port or what else in the router would break these apps.
By the way I'm running a WRT600N with the latest (Canadian) firmware.
I had similar problems with my router. I had to disable some of the packet inspection stuff. gr
