Zebedee setup through a firewall
Oct 06, 2005 7 Replies
Jump to replies (7)
Here is my issue I usually run a support application which is a customized version of UltraVNC server. It launches from a client machine and attempts to connect on port 5555 to my offices WAN IP. The firewall redirects the port to my computer and I can see my clients computer as soon as the connection is made to my VNC viewer operating on listening mode on port 5555.
It works great but now I am traveling and I a hotel and want to have the same functionality. There fore I need to forward the data coming in on port 5555 on my office machine to my laptop which is BEHIND a hotel firewall.
My solution to use Zebedee in reverse tunnel mode. So I run a client on my computer with the following configuration file.
debug true
verbosity 2 # Basic messages only
message "client"
detached false
Server false
Listenmode true
Tunnel 8000:*:5555
I then connect to the client by running the server on my computer
debug true
message "Server"
server true # It's a server
detached false # Detach from terminal
serverport 8000
clienthost SUPPORT
I get a connection established on the client on my work machine. So I have established the connection to the client through the hotel firewall and our work firewall. However when I try and run the VNC server at port 5555 on my office machines nothing happens on my laptop.
I have tried several variations of ports and commands. I think I fundamentally misunderstand something. Remember all I am trying to do is redirect traffic arriving at port 5555 to my laptop on the road which is also behind a firewall.
Can someone help me out with my configuration?
Thanks
Chas
Why not I have established a secure tunnel from my laptop (behind the hotel fireall that I cannot control) to the office computer (behind the firewall I do control). what I am trying to figure out is how I can forward the port through the tunnel. ie whats wrong with my configuration file.
As I said
"I get a connection established on the client on my work machine. So I have established the connection to the client through the hotel firewall and our work firewall. "
Volker
Are you running that under windows?
If so whihc flavor of ssh are you running and are you running the ssh server on the server or on your remote machine?
THanks
Lets not get into a semantics argument. I do NOT have an IP that is fully open to the internet. I have no control of the NAT box. So no have redfined it and not changed anything. Can anyone give some help?
"Chasman" wrote in news:1128623493.507767.221860 @g44g2000cwa.googlegroups.com:
If you're behind a FW you have no control over, then you have no shot at having inbound traffic for the RDS application host or client to be forwarded on the FW to the IP/machine that has the application running listening on the inbound port.
Maybe, that RDS application GoToMyPC may work for you.
Duane :)
It's not a hotel firewall, it's a simple NAT solution. Most every hotel has a NAT device or some other method, but they are not providing you with Firewall services. I've stayed in enough hotels across the USA to be sure of this.
I don't know Zebedee very well. But I'm using ssh -L for that case, and it works very good.
Yours, VB.
Yes, also under Windows.
Beside LSH I'm using OpenSSH. On Windows, I'm using OpenSSH with Cygwin.
The ssh server is on port 443 of a machine, which is reachable from the internet. It's my gateway machine.
Then I'm doing a simple ssh -p 443 -L 5900:192.168.23.42:5900 %GATEWAYIP% on the client, and that's it. VNC is then on 127.0.0.1.
Sometimes, one has to knock on the firewall/proxy of the hotel, though. For this case, I'm using corkscrew.
Yours, VB.
