PCTools Firewall
Apr 22, 2007 5 Replies
Jump to replies (5)
I have just installed and set up this firewall and it seems very good exept for one odd thing. After booting the machine and trying to get Internet access or email access i fail to connect.If I then Disable the firewall Access to both is ok. I then enable the firewall and Access to Internet and Email IS OK. Can some kind Person give me some help on This. Thanks Pete
Who cares how it seems? What matters is what is actually does, and I'm afraid to tell you that it's totally broken and utterly useless.
Well, should be.
Ehm... if you can disable it, why did you install it in first place?
Trivial: uninstall it. Problem solved.
Thanks for the absolute rubbish you have given in your reply
Can you point where this actually very reasonable subjections and suggestion should be rubbish? If you would carefully consider every detail, you'd come to the same conclusion.
pete wrote: Subject: PCTools Firewall
Put the proper content for your question into the body of your message, not just the subject, so as to provide context for the replies. The replies are not going to be found in the subject, but in the body. Your message body does not mention the PCTools firewall
Easy-to-use, free software utility - Vista 32-bit, XP, 2000 and Server 2003.
There are no docs available at the pctools site, the only access to instructions as to how to properly configure your application will be found after the install of fwinstall.exe from the pctools site.
Only someone with the s/w installed would have access to the configuration information, as far as I know.
A review sez "The default settings of the firewall will prevent several common attacks while allowing normal internet traffic. You can create your own rules using protocol, port and IP address - however it requires some experience with TCP/IP configuration, as no documentation is provided. The integrated software filtering engine will prompt you each time an unknown software is trying to connect to the Internet, giving you the option to block or allow current and future activities by the same program."
Search on 'pctools firewall configure' no quotes
even i tried this one but it deleted all my .exe file. this is ridiculus very bad exp
