Audit Nokia firewall rules
Apr 20, 2007 1 Replies
Hello All,
I would like to audit the firewall rules of a Nokia (Checkpoint) Firewall
Ideally I would like to export the rulebase into a file format for which I don't need the FW1 GUI - comma delimited would be fine. I want to take this stuff away to audit so I won't have access to the GUI
The export should either convert the shortcut names (addresses/ ports) to their numbers or I will need to export tables of those as well.
Or maybe there is a command line option for viewing the rules and group tables and I can grab the ascii output that is displayed
Any ieas?
Note: the implementations aren't particularly complex, no more than
100 rules each
I don't need to change the rules or import them back or anything like that - can I make sense of the raw config files do you think (do you know which ones I need?)
Free ones: cpdb2web
Or get a license for:
And I'm sure there are many more tools out there.
Br. Robby
