Outpost questions..
Nov 09, 2004 2 Replies
It stops, but you can always uninstall and re-install the free version.
It's the 'ad trashcan' window that's used for dragging-and-dropping ads into the 'ad blocking' plugin.
You might want to do a search at the forums at
for your questions - lotsa people there who use the program and probably came up with the same questions.
I have a few questions regarding Outpost firewall..
I installed an older version of the freeware program, and when it asked me if I would like to update I accepted. The result was that it UPGRADED to shareware v2.x, with a 30 day trial period. My question is, what happens after that ? Does it downgrade to the freeware version, or does it continue running, or does it stop ??
Seems there should be a difference between update and upgrade.
Second, when I run Hijack this it tells me that the ... \\Outpost\\trash.exe is running. What is that ?
Thanks for any help..
-- KHaled
e-mail: khaledihREMOVEUPPERCASELETTERS at fusemail dot net (correcting antispam crap..) please start your subject line with the string "==NG=="
My understanding is the pro version will stop functioning after 30 days. It does not revert to a freeware version.
Seems your right.
I don't know. Check the help files that come with it and find out the function of the trash.exe in outpost.
