Cannot discover devices with Cisco Works LMS
Apr 02, 2008 2 Replies
I used to use CiscoWorks 2000 a long time ago. Anyway, I'm trying out the 90-day trial version of CiscoWorks LMS running on a VMWare Windows
2003 Standard server. Using the Server Setup link, I've pointed to a Cisco router, configured the SNMP community and told CiscoWorks to discover from the router as a seed.
CW completes the discovery OK, but does not return any devices. I made sure the Windows firewall was turned off. I even installed a freeware SNMP browser and had it scan the network, and it returned the SNMP info for all my SNMP-enabled network devices, not just the one Cisco router.
I also tried pointing at non-Cisco routers and switches, and even scanning entire IP address ranges, but CW still doesn't find any devices.
Has anyone got any ideas about this? I'm guessing I skipped over something very basic, but can't imaging what.
Never mind; I had access-lists on the router blocking from the CW server's IP range. Duh.
Make sure you increase the standard time out and also number of tries. Personally I think that LMS should be renamed POS.
