Home network shares printer & files UNTIL a reboot
Feb 15, 2005 0 Replies
Using Norton Firewall 2004 on WinXP machines. I have set both PC's IP address in the Trusted Zone.
All works fine until one or both PC's are rebooted. Then in order to reestablish file and printer sharing, I have to unplug DSL from router, disable both firewalls, do a print job, and access files on the other PC. THEN I can enable both firewalls, go back onto DSL and every thing works fine for months.
I frequently do Live Update, Win Critical updates (sp2, etc.)
If it's set up and working, why won't it be that way after a reboot?
Thanks for any ideas!
