DLink DSL 504T Port fwd question.
Dec 22, 2004 0 Replies
Hello group.
I have recently received a DLink 504T DSL router from work as we were on ICS and this was prohibiting access to the VPN. Everything outbound is fine. However, I'd like to access my home computer via Remote Desktop from work and for some reason I can't. I was able to do this with ICS and the XP firewall forwarding rules.
I've setup the portforwarding as required (Win2k Terminal rule) on port 3389 TCP,UDP but it still won't get through. Nothing has changed except for the install of this router.
DHCP is on at the router end but I'm on a fixed IP.
Any ideas? I've saved my config and restarted the router, still no dice.
TIA.
