Dlink DSL 504 and connection refused problem
Jun 07, 2005 0 Replies
Hi all, I have a dlink dsl 504 router and a pc running a web server attached to the router. The web server is running on port 81 and I set the port redirection in the router configuration. When I try to access my web server from the extern I got an error:
The connection was refused when attempting to connect x.x.x.x
So I went to Advanced Filtering and Firewall section but the problem is that I can't see the rules listed! I can't do anything!
This is my firmware version and adsl version:
Current Firmware Version R2.21.002.05.b13au ADSL driver Version 1.3.5.03182002.0001
Another issue is the following: if I configure the remote control for the router, I can access the ext IP without any problem and log into the config interface but if someone else outside my network try to access it, it doesn't work!!
Can you please tell me what I can do in order to run a web server externally?
Thanks,
Ddz
