Hacking Firmware
Feb 01, 2005 5 Replies
Jump to replies (5)
Is it possible to hacking firmware of a wireless Linksys router to make it send the WEP key to an email?? Thanks!
In article , Stanley wrote: :Is it possible to hacking firmware of a wireless Linksys router to make :it send the WEP key to an email?? Thanks!
Possible? Sometimes. Legal? Not especially often.
It's not clear that it's worth the bother, considering that it's not especially difficult to crack a WEP key if you are within range of the device.
Before you try hacking you might want to master googling.
In article , Stanley wrote: :So can you tell me how?? Thanks
That's what search engines are for.
You really expect an honest answer?
Look... There's plenty of open access points Out There. Your local public library may even have one. Why make trouble for yourself?
