Replacement AC adapter/charger for Fluke One Touch
Feb 02, 2005 4 Replies
Jump to replies (4)
Does anyone know an online source for getting a replacement charger for a Fluke One Touch? Fluke product accessory site doesn't list one.
thanks
Hal
Perhaps the easiest thing, would be to find a compatible replacement. Unless it's really weird, there should be something available. What are the specs on it?
11 - 15 VDC 1.5 A. I was looking for a third party but am concerned about plug size. I am not sure if sizes are compatible for all volt/amp specs.
thanks for the response.
Hal
If you're in the US take it down to Rat Shack and find the matching plug. They've got their wall-warts set up so the plug is a separate item and you can mix and match--every once in a while they do something right and that's one of them.
Or give Fluke a call--it might be a spare part instead of an accessory.
As long as the specs match, it'll be fine. Also, it's not that difficult to replace the plug.
