Wireless security
Jun 10, 2005 2 Replies
Wireless security open original image
What would be the best solution for the wireless network using Cisco Aeronet? Does Cisco offer the solution? Thanks
You may wish to investigate the Cisco Solution Designer:
as well as the Cisco Product Advisor:
Hope this helps.
Brad Reese BradReese.Com Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272 Website:
M. Eteum schrieb:
I'm not paid by Cisco, but from what I've seen in the last 6 years with all major WLAN vendors: yes. But "best" depends on ... If your question would be more specific, help is possible. 42.
