Issue going from INSIDE to DMZ
Jun 10, 2005 1 Replies
Why when I add the line: static (dmz,inside) 10.200.1.0 10.200.1.0 netmask 255.255.255.0 0 0 do I loose my alias workings?
dmz: 10.200.1.x inside: 172.16.1.x outside: 63.174.x.x
At the moment from INSIDE I can't access the DMZ via the 10.200.1.x address. When I add the static line above I CAN access the DMZ via the 10.200.1.x address but I loose the ability to use my aliases...
My aliases look like: alias (inside) 63.174.xxx.xxxx 10.200.1.25
255.255.255.255
I currently have: static (inside,dmz) 172.16.1.0 172.16.1.0 netmask 255.255.255.0 0 0 which lets me go from DMZ to INSIDE... but I also want to go the other way.
Thoughts?
In article , Matt wrote: :Why when I add the line: :static (dmz,inside) 10.200.1.0 10.200.1.0 netmask 255.255.255.0 0 0 :do I loose my alias workings?
The PIX 6.x documentation does not define the relative priorities of the 'alias' and 'static' command, so what you are trying to do has undefined results.
:dmz: 10.200.1.x :inside: 172.16.1.x :outside: 63.174.x.x
:At the moment from INSIDE I can't access the DMZ via the 10.200.1.x address.
You should not need any configuration to allow that access. Something else in your configuration is interfering.
:I currently have: :static (inside,dmz) 172.16.1.0 172.16.1.0 netmask 255.255.255.0 0 0 :which lets me go from DMZ to INSIDE... but I also want to go the other way.
Have you considered
access-list nonat permit ip 172.16.1.0 255.255.255.0 10.200.1.0 255.255.255.0 nat (inside) 0 access-list nonat
and drop the static's ?
:My aliases look like: alias (inside) 63.174.xxx.xxxx 10.200.1.25 255.255.255.255
access-list nonat deny ip 172.16.1.0 255.255.255.0 host 10.200.1.25 access-list nonat permit ip 172.16.1.0 255.255.255.0 10.200.1.0 255.255.255.0 nat (inside) 0 access-list nonat static (insize,dmz) 63.174.xxx.xxxx 10.200.1.25 netmask 255.255.255.255
