I want to download the configuration using tftp server, but I can't seem to find the proper cable to use for connecting my laptop to the ethernet port on the router. Is it a crossover or straight through? I actually tried both kinds and still couldn't get the link light to turn green. Also, if anyone has a link to the proper cabling for all network devices that would be great.
Which cable do I use to connect PC to Cisco router?
May 20, 2005
Anytime that you hook up two end-devices like routers, PCs, print servers, etc. two together to one another, you'll need a crossover cable. A switch or hub already all have their ports crossed over, so hooking up an end-device to a switch uses a straight-thru cable. When…
Anytime that you hook up two end-devices like routers, PCs, print servers, etc. two together to one another, you'll need a crossover cable. A switch or hub already all have their ports crossed over, so hooking up an end-device to a switch uses a straight-thru cable. When hooking up two switch ports together, you need to straighten one out again, so you use a cross-over cable again.
Of course, there's tons of exceptions now-a-days, most for the better. Many switches now-a-days auto MDI/MDI-X so you don't need to think about these rules. Many end-devices can also auto-determine what you need.
Unfortunatly, some small SOHO CPE devices that are designed with the thought of only ever hooking up one PC to them expect a straight-thru cable and switch around the wires as they come in, so it crosses it over for you without your knowledge, and messes up the rules again, you need a cross-over cable to hook them up to a switch, which is opposit of what you would think.
Make sure that you plug your cross-over cable from your PC's ethernet port into the Cisco router's Ethernet or FastEther port.. And then the console cable from your serial port into the "Console" port.
The general rule is that you use straight-through cables when connecting to a switch, and cross-over when connecting two nodes directly.
Agree with above.
By default Cisco router ports are shutdown. You may have to log on using the console port and fix that first.
Here's link to lot of Wiring Stuff that you might find useful
-Ripple
Darth Tyrannus wrote:
Thank you for all your help. This leads to another question. When I plug in the crossover cable into the cisco router should the green link light become active? The reason I ask is because I used this particular crossover cable and went from ethernet to ethernet port on two routers and I got a green link light on the AUI. But when I used this same cable and plugged it into my PC and one of those routers, I didn't get a green link light.
Isn't the link light completely physical layer? Meaning, I shouldn't have to configure any procotcols or layer 2 addresses in order to obtain a green LED light on each device. This is where I'm running into problems. I need to understand the reason the link light turns green. I'm guessing that a signal is sent from one device to the other and if it received properly then both lights will become green. But this would require some sort of layer 1 protocol, correct?
In article , Darth Tyrannus wrote: :This leads to another question. When I :plug in the crossover cable into the cisco router should the green link :light become active?
Not if the interface is shutdown.
:Isn't the link light completely physical layer? Meaning, I shouldn't :have to configure any procotcols or layer 2 addresses in order to :obtain a green LED light on each device.
On router interfaces, the link layer is turned off until the router is told to turn it on. Amongst other things, this saves energy when the link is a laser GBIC...
:This is where I'm running :into problems. I need to understand the reason the link light turns :green. I'm guessing that a signal is sent from one device to the other :and if it received properly then both lights will become green. But :this would require some sort of layer 1 protocol, correct?
The "layer 1 protocol" involved could be as simple as "was able to detect a signal". But usually it's a little more complex than that: the link light does not, for example, usually light if the devices are not able to negotiate speed [but it -will- light if the two devices fail to negotiate duplex.]
:The reason I ask is because I used this :particular crossover cable and went from ethernet to ethernet port on :two routers and I got a green link light on the AUI. But when I used :this same cable and plugged it into my PC and one of those routers, I :didn't get a green link light.
Could mean that router doesn't want a crossover to talk to the PC. Could mean that the port speed couldn't be determined.
I finally got the crossover cable to work and both sides of the link are up and green. Now I am having a problem with ARP.
The cisco router has created an incomplete entry in its arp table for the workstation. The workstation has no arp entry for the router. I created ip address that were on the same C subnet. I manually added a static ARP entry to the workstation but could not ping the router. I am running Windows ME.
My next question is...how does Windows ME create ARP table? If this workstation queries the media, with the router being the only device on the media, shouldn't the router respond with it's MAC address? The only table that is partially complete is the routers ARP table, which has an incomplete entry for the workstation.
I cannot ping and am trying to get ARP to work correctly.
Need help! :)
In article , Darth Tyrannus wrote: :My next question is...how does Windows ME create ARP table?
It sends out an ARP broadcast packet requesting information on the remote destination.
: If this :workstation queries the media, with the router being the only device on :the media, shouldn't the router respond with it's MAC address?
Only if the router has been configured with an IP address on the link and configured to turn on the interface.
:The :only table that is partially complete is the routers ARP table, which :has an incomplete entry for the workstation.
An incomplete entry in an ARP table indicates that the device has recently sent out an ARP query but has not received a response, and that the device has not yet given on on waiting for the response.
An incomplete ARP entry is NOT proof that there is communications in either direction.
On the router side, do a "show interface" to check that the interface is considered to be up. You can also "debug packet" to see what is being received. On the Windows ME side... I'm not sure. If you had a later version of Windows, you could download libpcap and ethereal and snoop to see -exactly- what was on the wire. I don't know if that is supported on ME.
I did a show interface and everything seems to be ok on the router side. It has to be the Windows ME workstation. Maybe for some reason it's not responding with it's own IP address when ARPed.
I'm guessing my next step is to check on the web for Windows ME ARP behavior. Lord knows where I will find this...
The workstation works ok with ARP on my linksys router, but when I go to the cisco router it's a no go.
I finally figured out the problem. The ethernet interface on the router is not functioning properly. I finally decided to try the other ethernet interface and everything worked perfectly. I also tried another ethernet interface on a seperate router and again no problems. The interface that was giving me problems was acting sporadically. Ocassionaly the line protocol would come up, sometimes it would "transmits stalled: check cable connection:", and when I initially started working with it I was able to recieve some ARP info.
Thanks for your help Walter!
