Crossover or Straight-Thru? Please help.
Apr 04, 2005 3 Replies
Jump to replies (3)
You need to use a crossover cable to connect a pc to a router. (Had it right the first time around.) Your problem was more likely one of mis-configuring ip address & subnet values for this very abbreviated temporary network.
Simplest way to keep this straight is to think of all devices as belonging to one of two families:
First family is devices with multiple ethernet ports that just join together other devices at layer 2. This includes hubs & switches.
Second family is everything that might actually have something to say. This includes all computers, networked printers and other devices, and routers (which are really just special-purpose computers).
Connections between the two families always use a straight-thru cable. Connections within the same family always use a crossover cable.
For the purpose of installing a new IOS i connected my PC to a 2600 router thus:
Console cable between console port on the 2600 and Com 1 on my PC (no probs as you'd expect) and a CROSSOVER cable (wrongly labelled as straight-thru) between my NIC card and Ethernet 0/0.
I set up basic configuration and everything seemed fine except i couldn't ping my NIC's IP address.
I then noticed my mis-labelled cable was a CROSSOVER and swapped it for a STRAIGHT-THRU.
I re-configured the router from scratch and the line protocol is down, the link light on the ethernet int is out and my NIC is saying that there is a cable unplugged. Tried another STRAIGHT-THRU cable and still the same.
Plugging the CROSSOVER back in brings back limited functionality, link light etc! (still cant ping the NIC)
Which cable *should* i be using to connect my router to my NIC? I always assumed it was STRAIGHT-THRU?
Mikey Boy.
Thanks for the help with my somewhat rudimentary problem. I seem to have a problem with the LAN connection itself so i'll re-install the thing. Think i better hit the books gain too!
God Bless Ya
You might also check the condition of the cable itself that you don't have any crossed connections
