Connecting a Switch 1900 to a Router 2503
Jun 17, 2005 2 Replies
I connected my Router 2503 to my Switch Cat 1900. I took the advice of several others in the room, by using a transceiver to the AUI port on the router and used a straight through cable to the Switch. Unfortunatly there was no green light. On the Router, I gave the port an ip address and typed no shutdown. Was there any configuration I needed on the switch. Aslo how can I get my laptop on to the Switch? Or any other nodes?
Cheers.
I also wanted to know where i could get some good subnet excercises.
cheers
I figured out the problem. The cable that I was using was incorrect. I took the cable from my Broadband Internet Router that I used to my computer. I wasnt aware that it was a cross over cable, which in fact strange. Apparently you can use Straight through cables and Cross over's.
Now that i have sorted the problem out, Please disregard the above cry for help. (but beware i shall be crying for more help in the future, so you guys are not safe!) loool
Cheers.
