VPN SBC/ATT&T DSL connection problem
Nov 01, 2006 1 Replies
VPN SBC/ATT&T DSL connection problem open original image
OS on laptop is Win XPSP2. Using Cisco VPN 4.6.02. and broadband isp is SBC/ATT&T with 2WIRE dsl modem/router with built-in wireless. The error message I get is "The specified remote computer could not be found. Verify that you have typed the correct computer name or IP address, and then try connecting again". I'm trying to connect to my office network from home. When I ping the ip addresses of the terminal server and server I get a response, but when I ping the names of the terminal server and server I don't get any response. I've done a search on connecting with vpn and dsl and it seems that there is a lot of problems with using vpn connection with sbc dsl. First of all does SBC dsl allow this and could it be something in their dsl software that is installed on the laptop that is preventing this? Any help or insights would be greatly appreciated.
You may also wish to investigate the 2Wire Forum:
As well as the SBC/AT&T DSL Support Forum:
Sincerely,
Brad Reese Cisco Technical Forums
