CISCO 1841 - X.25 - XOT - EICON
Nov 01, 2006 0 Replies
Hi:
We have a following configuration.
Server 1 (Eicon Card- Interface X.25) --> Eripac (Ericsson Switch X.25) -> Siemens Exchange EWSD
With this configuration the Server 1 woking normally.
We have to change for:
Server 1 (Eicon Card - Interface X.25) -> Router Cisco 1841 -> Router Cisco 1841 -> Siemens EWSD
The configuration in the CISCO 1841 (Server 1) is:
version 12.4 service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname FTAM_X25 ! boot-start-marker boot-end-marker ! enable secret 5 $1$/zXP$KK4pNiMatl/Bi6D.us6zY/ ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ! ! ! x25 routing username cisco password 0 cisco ! ! ! interface FastEthernet0/0 ip address 192.168.25.128 255.255.255.0 duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/0/0 no ip address encapsulation x25 dce no ip mroute-cache x25 address 744802100141 x25 htc 85 x25 facility windowsize 7 7 x25 facility packetsize 128 128 x25 nvc 8 clockrate 64000 ! ip classless ! ip http server ! snmp-server community public RO snmp-server enable traps tty x25 route 744802100099 xot 192.168.25.102 x25 route 744802100100 xot 192.168.25.103 x25 route 744802100148 xot 192.168.25.104 x25 route 744802100302 xot 192.168.25.105 x25 route 744802100127 xot 192.168.25.106 x25 route 744802100147 xot 192.168.25.107 x25 route 744802100101 xot 192.168.25.108 x25 route 744802100143 xot 192.168.25.109 x25 route 744802100117 xot 192.168.25.110 x25 route 744802100119 xot 192.168.25.111 x25 route 744802100125 xot 192.168.25.112 x25 route 744802100121 xot 192.168.25.113 x25 route 744802100123 xot 192.168.25.114 x25 route 744802100103 xot 192.168.25.115 x25 route 744852100500 xot 192.168.25.116 x25 route 744852100504 xot 192.168.25.117 x25 route 744852100502 xot 192.168.25.118 x25 route 744852100506 xot 192.168.25.119 x25 route 744852100522 xot 192.168.25.120 x25 route 744802100134 xot 192.168.25.121 x25 route 744806100706 xot 192.168.25.122 x25 route 744806100700 xot 192.168.25.123 x25 route 744807100900 xot 192.168.25.124 x25 route 744802100141 interface Serial0/0/0 x25 route 744802100132 xot 192.168.25.101 ! control-plane ! ! line con 0 line aux 0 line vty 0 4 login local ! end
Using the command "debug x25 all" receive the following message:
*Oct 25 20:21:38.652: Serial0/0/0: X.25 I R1 Call (24) 8 lci 8
*Oct 25 20:21:38.652: From (15): 744802100141300 To (15):
744802100132301
Oct 25 20:21:38.652: Facilities: (0)
*Oct 25 20:21:38.652: Call User Data (4): 0x03010100 (unknown)
Oct 25 20:21:38.656: [192.168.25.101,1998/192.168.25.128,17777]: XOT O P2 Call (30) 8 lci 1
*Oct 25 20:21:38.656: From (15): 744802100141300 To (15):
744802100132301
Oct 25 20:21:38.656: Facilities: (6)
*Oct 25 20:21:38.656: Packet sizes: 128 128
Oct 25 20:21:38.656: Window sizes: 2 2
*Oct 25 20:21:38.656: Call User Data (4): 0x03010100 (unknown)
Oct 25 20:21:38.676: [192.168.25.101,1998/192.168.25.128,17777]: XOT I P2 Clear (5) 8 lci 1
*Oct 25 20:21:38.676: Cause 0, Diag 76 (DTE originated/Facility not provided w hen expected)
*Oct 25 20:21:38.676: Serial0/0/0: X.25 O R1 Clear (5) 8 lci 8
*Oct 25 20:21:38.688: Serial0/0/0: X.25 I R1 Clear Confirm (3) 8 lci 8
*Oct 25 20:21:38.688: : XOT O P7 Clear Confirm (3) 8 lci 1
I you have any idea what happened.
Helder Perez
