police not working on 4500
Nov 01, 2006 3 Replies
Jump to replies (3)
I am trying to limit traffic entering and leaving a L3 int on my 4500 using the following config but it appears to do nothing..
class-map match-all test match access-group 100
policy-map limit-traffic class test police 400000 1000 exceed drop
int gi 3/1 service-policy input limit-traffic service-policy output limit-traffic
access-list 100 permit tcp host 10.0.0.1 any eq ftp-data access-list 100 permit tcp any eq ftp-data host 10.0.0.1
It sometimes shows me a match on the show policy-map int.. but nothing ever on the conform or drop -- no matter how much traffic I generate or what I set the limit to.. my ftp's whizz through at full speed.
I even set the ACL to permit ip any any and the behaviour was the same..
Thought I was maybe missing a global 'MLS qos' style command or an interface traffic-shapping - but no.
Any ideas anyone??
Please!!
TIA
T
Maybe you are testing with passive FTP? If so, then ftp-data port is not used for ftp data...
Good luck,
Sylvek
PS. If you come up with an easy way of detecting passive ftp data streams post it here. I'd like to know this too.
Hi Sylvek,
No.. because I also tried with permit ip any any to catch everything from these test machines - but still no luck.. I will try another IOS today to see if it is related to a bug.. and if not then I am lost!
Just for info.... it was the 'mls qos' style command! Doh!.. has been replaced by simply 'qos'. "mls qos' is still there but is now undocumented and phasing out.
would be easier if they had an IOS that detects you are using qos when you type in class-map!
