Speed Mismatch?!?
May 07, 2006 25 Replies
TAC
Here is how I would put the case.
Choose the simplest setup that can reproduce the issue i.e. no stack link involved.
use 3 ports (or ideally 4)
2 x 1G 2 x 100M
Do the performance tests and send them the results.
Send full sh run and relevant sh int to show that the interfaces are reporting as running clean.
If you do it like this and make NO changes to anything betwen runs then they cannot get diverted down the blind alleys that you have already investigated thoroughly. Can they???
Let's call the computers Gi1, Gi2 and Fa1, Fa2.
If you show Gi1 Gi2 works OK AND Fa1 Fa2 is OK then ask them to fix Gi1 Fa1 which is broken.
One advantage of using iperf is that they can reproduce it for themselves.
Send H:\\>iperf -v iperf version 1.7.0 (13 Mar 2003) win32 threads H:\\>
If that is the path you choose.
It would be interesting to know if it was indeed packets towards the end of a burst that were disappearing.
Remember that iperf by default will only send
8k (or about 5 or 6 packtes) in one burst. The TCP then send as it sees fit:-) which can only reduce the burst size further.
IDEA:- Try a test with an iperf buffer of less than 1 packet. If that works, you MAY be able to improve the local performance by setting the TCP Receive Window to just over 1 packet (less than two). Or one packet exactly? 1460 bytes usually. Why not try it? Set the MS Windows TCP Receive Window to 1460 and see what happens.
You will also have to set the other end to send TCP acks for each segment.
available on XP and 2003 Server. Set to ONE.
iperf -c 1.1.1.1 -l1460 :: I have had a look and it is not :: clear that this does what I thought.
This will though destroy WAN performance.
If my current model is correct and the issue is indeed that the buffers between Gi ports and Fa ports are not working then adding a "buffering" switch to the path would help.
source--Gi-->-buffer-sw--Fa-->-Stack--Fa-->-sink
The other thing that adding switches to the path does is that it adds latency. To a good approximation all modern switches are store and forward. Each switch in the path adds 1 Packets worth of Transmssion Delay. The value is dependent on the length of each packet and the speed of each interface.
IPERF I have had a look and I don't think that IPERF does wait for all of the acks after sending a block. It is not clear to me at present.
TAC has been "...[looking] at the captures..." for the last day+.
No word yet.
This _is_ a clue. It's buried above, but the reason it took me a year and a half to realise that somthing was horribly wrong, not just slow servers etc - was because I have an extra switch in my path compared to the rest of the users. I can get 30mbit/sec to Gi. Still crapy and asym....80 going to Gi, 30 coming from.
I have not tried exactly what you have above, I did this:
source-gi-->buffer-sw-Gi-->Stack-->Fa-sink.
IOW, I did not try buffering w/ a switch that had an Fa link to the stack...I stayed on Gi.
I also took this a little further and setup an 4x etherchannel, still all gi...I _WAS_ trying to buffer somthing somwhere, not really knowing how but wondering if packet A overran packet B to the point that the stack could not see the etherframe signature of A anymore...reports no drop becuase it saw no packet in the first place. I know there is a drop somwhere, where is this drop occuring? Packet drop counters increment if and only if IOS is aware that a drop has occured...I doubt interface counters care what goes on between the guts that contect other interfaces. Stack ring counters? Still don't know how to get any.
Anyway, I have time right now to try what you suggest.
< time passes >
It works at 65 mbit/sec.
Gi-source-->buffer-sw-Fa-->stack-->Fa-sink
iperf...
Recall that I'm unable to conect from fa-client to gi-server to run the test. I get "connection failed" If I fail to lanuch "ipsef -s" on Gi, I get "Connection refused" I have the same problem with pcattcp. Thing is client-fa-->server-Gi is not the slow path. It's slower that it should be using robocoy.
Gi-server-->stack-->Gi-sink
...kicks so much ass. Very fast.
I got no clue about the inerds of a 3750...is there supposed to be a buffer/queue dedicated for moving data between fa and gi?!?!?!?
I'm been thinkg about the odds of a gi-host overruning an fa-host. I don't see it. TCP does send some segments out...but do not most TCP stacks "wait" at some point for some ACKs beofre sending more data? In UDP, I could see Gi sending so much that packets just drop in the switch once egrees queues filled up. Or does it not work that way? I'm just making assumption based on prior data; not knowing how much value said prior data/experiance has in this case.
I have just remembered something. GI Ethernet has a feature called "Pause Frames"
############ # Begin guesswork ############ These are designed to prevent or reduce the number of 'overrun frames' (my terminology) sent. Some network protocols can send wire rate bursts of frames that can overflow the buffers in intermediate or in end stations. Such overflow packets are lost.
Pause frames are sent by the station that is experiencing the overflowing buffers towards the source and in some way signal to the source to slow down a bit.
############ # End guesswork ############
I have no real idea if you network _needs_ pause frames to be operational to function (I would strongly doubt it) however what I was wondering was if you did in fact have partially operational pause frames and maybe there might be a bug in the way that the pause frames were operating.
If this model is correct you will NOT be seeing lost packets on the network.
I know nothing about pause frames. They could for example not show up on a sniffer 'cos they could quite reasonably be implemented at Layer 1 and a cheap and cheerful sniffer could quite reasonably not be able to see them.
You could quite reasonably post this issue on comp.dcom.lans.ethernet. Leave in the cisco references. Someone there who is familiar with the pause frame implementation for example may just see the issue right away.
Out of interest, you aren't using huge TCP windows are you? i.e. you haven't got TCP Window scaling turned on? Consider all of your hosts.
If you were getting buffer overflows you should I would imaging be seeing output drops on the Fa interfaces. sh int | inc drops If there are none then maybe the counters are broken or maybe the drops are internal to the switch or maybe there is a 'pause frame bug'.
I thought about Pause frames too.
I'm certain I now even less about them than yourself.
I do know that I have all flow-control turned off on the stack, as is the default. Useing braodcoms diag tools for thier NIC's...During link negotiation, the stack is saying "I don't do flow control" and the NIC, who has flow control set to auto, noted this.
I'm watiing for TAC to say _somthing_ but at this point they have not responded to what I set or asked any more questions. I will bring up flow control with them.
I looked into flow control because, befor I realized that _ALL_ my GigE NIC's are affected, I was thinking "bad driver" and the RTM driver for the broadcom NIC's in question did, arrounding to broadcom, have a bu in them with reguards to flow control...the older driver would revice a pause frame and them pause for too long.
What brand/models do you have this experience with? I've currently got two 6509's curreently deployed with Gig hard coded on both ends of the link (auto disabled). I've also got 2 2948G-48 switches deployed with gig hard coded on both ends of the link. We get a full 1gb throughput without a single error on the port.
Ryan
Personally, my experiences have been just the opposite. Honestly, I can't quote the IEEE standard on this one as I've never looked it up and just assumed that you could set it or put it on auto just like
100mb.
I've currently got 6500's using the WS-X6148-GE-TX copper 48 port blades, as well as 2948G's that are hard coded to gig. Both on the server and the switch.
I'm not saying its not against IEEE, but If it were against IEEE standards, then why would the server as well as the switch allow this?
Ryan
