EIGRP Question.
May 07, 2006 3 Replies
Jump to replies (3)
Looking at this, Could someone please look at my notes in parentheses and tell me if I got this correct?
If the AD (advertised distance) is less than the FD (feasible Distance) of the best route, then it is a feasible successor. The successor is the best route and is put into the IP routing table.
Langley#show ip eigrp topology P 10.1.2.0/24, 1 successors, FD is 768 via 10.1.3.1 (768/256), Serial0 (This is the successor, currently used route) via 10.1.5.2 (1280/256), Serial1 (256 < 768, this is a FS).
P 172.16.90.0 255.255.255.0, 2 successors, FD is 0 (am I correct in assuming that the FD is really 46251776?) via 172.16.80.28 (46251776/46226176), Ethernet0 (This is the successor) via 172.16.81.28 (46251776/46226176), Ethernet1 (This is the successor) via 172.16.80.31 (46277376/46251776), Serial0 (not a FS, as the AD = FD)
Thanks crzzy1
You are correct. Not sure why the FD is reported as 0 for the 172.16.90.0 route. Could be a bug in your IOS version.
I think that perhaps since this has 2 load balancing successors which both have equal cost AD and FD, the route just has an incorrect zero for the FD. I wonder if you had unequal cost successors (using the variance command) if they too would have an FD of zero then.
One other question,
Why does the last entry show up (via 172.16.80.31)? Wouldn't you need "#show ip eigrp topology all-links" in order to see that which is not a feasible successor? and yet, there it is.
According to my text, routes that are not successors or feasible successors are not shown in #show ip eigrp topology yet these routes can be found in #show ip eigrp topology all-links
thanks, crzzy1
