Reset Defaults on Catalyst 2950
Feb 16, 2006 6 Replies
Jump to replies (6)
Hi, how can i reset hardware factory defaults on a Cisco Catalyst 2930 without using a cable?
thanks
You could enter the command:
"wr erase" and then do a reload
snipped-for-privacy@gmail.com wrote:
Thanks Jones...
But i can't telnet the switch because i don't know its ip.
byez
so why don´t you connect via console cable ? ;-) There´s no other way to be at least connected to the switch with a console cable. Turn the switch off (Power cable) Turn it on while pressing for at least 5-10 secs the mode button. now a dialog should appear. now you have accesss to the file system and can delete the config file.
Mike
schrieb im Newsbeitrag news: snipped-for-privacy@o13g2000cwo.googlegroups.com...
Hi, Michael!
Because i don't have the blue cable. :)
Danke!
There is no way to break into a Cisco Router/Switch without the "Blue" (older ones are black) cable.
Hold in the mode button for 10 seconds and you will erase the config.
