Cisco 3620 Router - Boot up Problems
Dec 07, 2006 4 Replies
Jump to replies (4)
Cisco 3620 Router - Boot up Problems open original image
I have a Cisco 3620 router, which would not Boot up. It displays complete garbage in special characters (like a corrupted file). What can I do to fix this error? Any help would be appreciated.
Try setting your serial port to 115200 - it's possible somebody changed the line speed in the configuration and you're seeing a line rate mismatch.
P.
There are other possible speeds too!!!
Quite a few.
I am not sure but I think that if you go into the rom monitor (in hyperterm [cntrl]break during startup) that the rate always reverts to 9600,n,1,no-handshake. Then you can configure the router to start ignoring the config file. Then you can do a "show startup-config" to see what it is set to and reboot knowing how to set your terminal.
If you look for the "password recovery" doc for your platform you wll get the idea. Or ask for more help.
Hi Ken,
You may wish to investigate Hardware Troubleshooting for the Cisco 3600 Series Router:
Hope this helps.
Brad Reese Cisco Repair
