upgrade IOS 12.2(25) EWA6
Sep 11, 2006 3 Replies
Jump to replies (3)
sh ver Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA6, RELEASE SOFTWARE (fc1) Technical Support:
(c) 1986-2006 by Cisco Systems, Inc. Compiled Fri 02-Jun-06 15:20 by ssearch Image text-base: 0x10000000, data-base: 0x114ED458
ROM: 12.2(20r)EW1 Dagobah Revision 226, Swamp Revision 34
edu-barnum-c4506 uptime is 4 days, 3 hours, 16 minutes System returned to ROM by reload System restarted at 10:29:39 UTC Thu Sep 7 2006 System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 10) with 262144K bytes of memory. Processor board ID FOX1021013E MPC8245 CPU at 266Mhz, Supervisor II+ Last reset from Reload
1 Virtual Ethernet interface
146 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Do I need to upgrade IOS? I also want to use ssh but this version does not support ssh. But I would need basic layer 3 routing
Hi Tony,
You may wish to investigate the Cisco 4000 Series Switches Software Advisor:
Find software compatible with your hardware Find software compatible with features you need Compare the features in different software releases Research a software release
Sincerely,
Brad Reese BradReese.Com - Cisco Jobs
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Resumes
There are some newer versions out there 12.2.31-SG and 12.2.31-SGA but your version is relatively new so if it is working well and you don't need any newer features why upgrade?
The version you have installed includes Basic Layer 3 (Static Routes and RIP) to get the SSH functionality you need to install a BASIC L3
3DES image or IP BASE SSH (in later code versions they have renamed BASIC L3 to IP BASE).
I guess that you need a support contract in place to get the SSH capable image or speak to your reseller.
If you do decide to upgrade be sure to check out the release notes as your ROMMON may also need upgrading.
James
t> sh ver
No need to upgrade the software but change the feature set.
You have Basic L3 feature set, and you need Basic L3 3DES feature set, which supports SSH. cat4000-i9k91s-mz.122-25.EWA6.bin
