unknown Card error with 1721
Aug 31, 2007 4 Replies
Jump to replies (4)
unknown Card error with 1721 open original image
Hi all, I have been trying to configure a 1721 router with one shdsl wic (WIC-1SHDSL-V3=) and one ADSL wic (WIC-1ADSL-DG=) and currently i receive a unknown card at startup (shown below) and nether cards shows up when the router has fully loaded. Both cards are new out of the box and the router has been used before in another environment. I have checked on the cisco site to confirm the cards are compatible and also i have loaded the correct IOS according to cisco.
Jan 27 05:05:56.979: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command. System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1) TAC Support:
(c) 2003 by cisco Systems, Inc. C1700 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x6b641c
Self decompressing the image : ################################################################################################################## [OK]
Smart Init is enabled smart init is sizing iomem ID MEMORY_REQ TYPE MainBoard 0X00027A80 1721 0X000F3BB0 public buffer pools 0X00211000 public particle pools
0X0050 0X00000000 UNKNOWN Card in slot 0
0X04DA 0X00000000 UNKNOWN Card in slot 1 TOTAL: 0X0032C630
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 7196180 bytes to IO Memory.
PMem allocated: 56585148 bytes; IOMem allocated: 10523716 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(23), RELEASE SOFTWARE (fc5) Technical Support:
(c) 1986-2007 by cisco Systems, Inc. Compiled Tue 24-Jul-07 14:47 by stshen Image text-base: 0x8000816C, data-base: 0x80B9DC14
cisco 1721 (MPC860P) processor (revision 0x500) with 55258K/10278K bytes of memory. Processor board ID FOC09284FST (1016682941), with hardware revision
0000 MPC860P processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Press RETURN to get started!
Jan 27 05:04:12.151: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up Jan 27 05:04:16.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up Jan 27 05:04:16.463: %PARSER-4-BADCFG: Unexpected end of configuration file.
Jan 27 05:05:20.015: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down Jan 27 05:05:21.015: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down Jan 27 05:05:27.695: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(23), RELEASE SOFTWARE (fc5) Technical Support:
(c) 1986-2007 by cisco Systems, Inc. Compiled Tue 24-Jul-07 14:47 by stshen Jan 27 05:05:27.735: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router>en Router#sho ver Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y7-M), Version 12.3(23), RELEASE SOFTWARE (fc5) Technical Support:
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes System returned to ROM by reload at 05:05:56 UTC Fri Jan 27 2006 System restarted at 05:04:08 UTC Fri Jan 27 2006 System image file is "flash:c1700-y7-mz.123-23.bin"
Configuration register is 0x2102
Any Ideas ?
Many Thanks
Alex
0X0050 0X00000000 UNKNOWN Card in slot 0 0X04DA 0X00000000 UNKNOWN Card in slot 1 TOTAL: 0X0032C630
0000 MPC860P processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0. 1 FastEthernet/IEEE 802.3 interface(s) 32K bytes of non-volatile configuration memory. 32768K bytes of processor board System flash (Read/Write)
Any Ideas ?
Many Thanks
Alex
Search of
for [WIC-1ADSL-DG IOS] returns
says:-
The ADSL over POTS WIC with Dying Gasp Support (WIC-1ADSL-DG) is available on the Cisco IOS 12.3T Release starting with the Cisco IOS
12.3(7)T Release on the Cisco 1700/2600/3700 series routers. This WIC is supported on the 1800/2800 series ISRs starting with the Cisco IOS 12.3(8)T Release, and on the 3800 series ISRs starting with the Cisco IOS 12.3(11)T Release.
that the V3 card needs 12.4.
Minimum Cisco IOS software release required for new WIC WIC-1SHDSL-V3 support.
1721, 12.4(2)XA or 12.4(3rd)T
Minimum IOS rev 12.3(7)T
So, you're below the minimum rev for both cards, which is why they don't show up, you can't run an IOS for a card released after that rev of software was.
(12.3(y)T is newer at all times than any 12.3(x) without the T, even if x > y).
So, looks like you have to get yourself up to 12.4(x)T or 12.4(x)XA at the minimum to support both cards.
