2610 and 2610XM can not see NM-1E-2W
Jun 27, 2006 4 Replies
Jump to replies (4)
2610 and 2610XM can not see NM-1E-2W open original image
Both of my routers 2610 and 2610XM can not see a NM-1E-2W. What's wrong? Is that because of the IOS are too old? If that's the case, where can I download newer ones?
Thanks, ZP
Details are below:
2610XM: Copyright (c) 1986-2002 by cisco Systems, Inc. Compiled Tue 24-Sep-02 01:12 by pwade Image text-base: 0x8000808C, data-base: 0x80B1F640
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 1 minute System returned to ROM by power-on System image file is "flash:S26XMB-12.2.12a"
cisco 2610XM (MPC860P) processor (revision 0x100) with 27648K/5120K bytes of memory.
2610: Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-I-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2) Copyright (c) 1986-1999 by cisco Compiled Tue 07-Dec-99 02:12 by phanguye Image text-base: 0x80008088, data-base: 0x807AAF70
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
MIMH069 uptime is 10 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.120-7.T"
cisco 2610 (MPC860) processor (revision 0x202) with 20480K/4096K bytes of memory.
You're trying to put a module for only the 36xx (and up) line into the
2600 line. Won't work. Sorry. The only "expansion" module that works in the 2600 is the NM-2W. The only ethernet modules are the NM-1E and NM-4E.
The Combo expansion modules only work in the 3600's.
Thanks for the clarification.
Can the 2610 and 2610XM take any FE NM? And are there any minimum IOS required for that?
What are the latest IOS for 2610 and 2610XM?
12.3T ?
Thanks, ZP
Hi ZP,
You may wish to investigate Cisco 2600 Documentation:
as well as the Cisco IOS Software Selector:
Hope this helps.
Brad Reese BradReese.Com - Cisco Network Engineer Directory
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
Yes. The 2600 series works with any of the 16-port EtherSwitch Network Modules series such as the NM-ESW-16.
The 2610XM can run 12.4.9T if you max out the flash and RAM. The non-XM 2600s aren't supported beyond 12.3. The 2691 is the only non-XM
2600 that supports the T train. 12.3.9(GD) is the best you can run on the 2610. J
